Hello Guest it is October 23, 2026, 05:23:07 AM
Author Topic: Mach4 / Probing / tool measure scripts  (Read 104718 times)
« on: May 04, 2022, 03:04:24 PM »
Hey, guys. I decided to finish some scripts for probing. These scripts will find use mainly on larger machines with ATC spindles, or machines equipped with automatic tool change.
The first one is M101 - tool measurement.
This macro can only be run from the MDI or from a program, e.g. after a tool change, with this command.
The script works fully automatically with tools with a smaller diameter than the probe seating area. For larger tools, operator intervention is required.
It is also necessary that the tool diameter in the tool table agrees with the reality.
When the cycle is finished, the system is reset to the state before it was started (spindle on, cooling, offsets...). You don't have to think about anything. The script thinks of everything for you.
Feel free to ask anything you are interested in right here.
Price US $79.00
https://www.ebay.com/itm/224967863049?hash=item3461212b09:g:NooAAOSwQGJib9NJ
P.S. I will also post the script for checking the cutter edge soon.
