Hello Guest it is November 12, 2026, 02:01:57 PM
Author Topic: ShuttlePRO Spindle Override ++ and --  (Read 16165 times)
Offline Azalin
  •  191 191
« on: May 04, 2022, 09:10:29 AM »
In my lathe I have a ShuttlePRO. I have assigned 2 buttons as "Spindle Override ++" and "Spindle Override --". These functions works but the increments are too big. In my case, my spindle motor RPM range is 100 to 1510. When I press the ++ button the increments are like:
100 > 600 > 1100 > 1510
However I'd like to get smaller increments like 100 RPM each press. And same amount for -- (decrease RPM).
I've searched the lua scripts and couldn't fine any related spindle override method or similar.
How can I control the ShuttlePRO plugin spindle override values?
Suat
Offline Azalin
  •  191 191
Re: ShuttlePRO Spindle Override ++ and --
« Reply #1 on: May 05, 2022, 08:14:31 AM »
Another problem is when the Incremental Jog Step is set at 0.0010 and 0.0001 the inner wheel doesn't work.
Offline Azalin
  •  191 191
« Reply #2 on: May 15, 2022, 07:39:54 AM »
Nobody?
Offline Rimmel
  •  284 284
« Reply #3 on: June 02, 2022, 06:16:41 AM »
These plugins are basically locked.
