Hello Guest it is November 13, 2026, 03:45:13 PM
Author Topic: Spindle Height  (Read 22467 times)
Offline kolias
  •  1,165 1,165
Spindle Height
« on: May 03, 2022, 01:53:21 PM »
Although I built in the past few CNC machines I can’t remember what is a comfortable height to set the Z axis support plate. If I use a 3/8 bit which is about 3” total length there is some room for the spindle to go up/dn but if I use a 1/8” bit which is about 1.5” total length then the available room is really small and most likely will trigger the limit switch.
Any hints how to go about this setting?
Nicolas
