Hello Guest it is October 24, 2026, 11:44:06 PM
Author Topic: Mach4 manual input  (Read 6238 times)
Offline Rimmel
  •  284 284
Mach4 manual input
« on: April 30, 2022, 10:32:53 AM »
Moving from mach3 to mach4 and a bit perplexed at the loss of the manual input text box.
I know there is an MDI window, but can this be set to run a single line on "enter" like mach3? With an up/down arrow recall of last commands?
I use this on a Dev machine as it is very handy for samples up and/or ceating programs on the fly.
With the MDI it seems very long winded as I have to type everthing in again and again, then go to a mouse from the keyboard to make it run.
thanks
Re: Mach4 manual input
« Reply #1 on: April 30, 2022, 10:17:58 PM »
you could probably program that feature if you wished but Mach4 natively treats an <Enter> as a new line in a multiline MDI file.
If you had a physical button that had the function <MDI Cycle Start>, that would allow you to type your MDI code and run it just by hitting the button, as opposed to <Enter>.
You could alternately use the Keyboard plugin and assign the <Enter> button on you keyboard to mean <MDI Cycle Start>, although then you'll almost certainly hit <Enter> ay some stage
and will accidentally trigger movement from your machine when you are not expecting it. I could not recommend that even if it does work.
« Reply #2 on: May 12, 2022, 03:37:10 PM »
Like Craig said, you can add a button to do a Cycle Start.
The Cycle Start Function looks at whether it is currently on the G Code Tab or MDI tab and it will either run Cycle Start or MDI Start.
Chad Byrd
