Hello Guest it is October 23, 2026, 04:12:41 PM
Author Topic: spindle speed problem  (Read 51396 times)
Re: spindle speed problem
« Reply #10 on: April 30, 2022, 03:58:34 PM »
Did you type it in then press return?
« Reply #11 on: May 01, 2022, 01:50:32 AM »
ok thanks for your patience
I type 10 in the dro as I press enter it returns to 100
« Reply #12 on: May 01, 2022, 02:58:46 AM »
In my experience the enter key doesn't work with the M3 DROs, press return instead?
« Reply #13 on: May 07, 2022, 01:44:54 AM »
good morning
I solved the problem, anyway thanks to John Haine for your patience !!!! ;) ;)
« Reply #14 on: May 07, 2022, 04:39:47 PM »
Well done...what was the solution?
« Reply #15 on: May 08, 2022, 12:50:53 AM »
ok John Haine in mach3 / general config under "spindle OV increment" I put 10 (there was 100) and everything is back to normal, I don't know how and why it changed, on the other hand I solved it !! ;)
« Reply #16 on: May 08, 2022, 03:12:35 AM »
Excellent!
