Hello Guest it is October 23, 2026, 04:11:20 PM
Author Topic: spindle speed problem  (Read 51395 times)
« on: April 29, 2022, 05:16:24 AM »
good morning
I have a problem with the spindle speed that I cannot solve, without loading the gcode I turn on vfd then the spindle I press the "+" key and it increases the speed a little and up to here it is ok if I load the gcode and the speed is "M3 S10000" I start working and press the "+" key the speed doubles, I would like (if possible) that it increases slightly there is a way to set
the increase in speed?
I thank those who can help me, I hope I have explained.
Re: spindle speed problem
« Reply #1 on: April 29, 2022, 07:16:02 AM »
Mach 3 or Mach 4?
« Reply #2 on: April 29, 2022, 08:37:46 AM »
mach3  ver.3.043.062
« Reply #3 on: April 29, 2022, 04:25:38 PM »
OK, now we know more about the software, what hardware configuration do you have?  How is the VFD speed controlled from your computer?
« Reply #4 on: April 30, 2022, 05:34:31 AM »
thanks for the answer, I have a 4 axis tb6600 vfd card connected to the Modbus RS485 com port, to increase and decrease the speed I use the "+/-" keys, I state that first everything worked regularly then (I don't know why) it arose this problem. I enclose xlm
« Reply #5 on: April 30, 2022, 05:36:50 AM »
screen
« Reply #6 on: April 30, 2022, 06:15:52 AM »
So essentially the speed is controlled by a modbus connection between computer and VFD, right?  And when you say +/- keys, I assume you mean the spindle speed override on the mach3 screen?
« Reply #7 on: April 30, 2022, 07:28:16 AM »
just the speed is controlled by a modbus connection between computer and VFD, the +/- keys' override the spindle speed on the exact mach3 screen
« Reply #8 on: April 30, 2022, 07:51:04 AM »
Try changing the %S DRO to say 10 rather than 100.
« Reply #9 on: April 30, 2022, 12:43:34 PM »
I tried to set 10 in the dro but it always returns to 100 I don't know if there is to set it somewhere else
