Hello Guest it is September 09, 2026, 04:54:40 PM
Author Topic: Mach3 R2.56 Problem with feedback spindle control  (Read 10572 times)
« on: October 25, 2007, 03:11:28 PM »
Spindle feedback control does not control and keeps increasing way beyond S*********X setting. All settings the same as in older versions and QUANTUM where spindle feedback control works perfectly. It seems to me that any version of MACH 3 with the BRAIN addition has this same problem. Has anyone had this problem and found the correction? I only updated to take advantage of "BRAINS" for additional keypad control of the "FLOOD TOGGLE" which works very well.
Offline TonyP
  •  132 132
Re: Mach3 R2.56 Problem with feedback spindle control
« Reply #1 on: October 27, 2007, 11:05:27 AM »
This sounds just like the problem like the problem that I had with V2.52. (See my post OCT 11th) I think that its something to do with the new drivers. I got round it by re-installing an older version in another directory and letting it overwrite the drivers. Its worked ok since. Did you do ther full install with drivers? I only realised later that there is an option to not install them.
Tony
« Reply #2 on: October 27, 2007, 01:14:45 PM »
Thanks for the reply Tonyp, I did find the solution to the problem and as it is often said it was in the settings. I had my index debounce set too high and once set to "1" all works fine up to the Max RPM of 4000. The Brain that I added to control flood toggle from the key board also works very well. So Version R2.56.1 is all OK for My setup.
