Hello Guest it is October 22, 2026, 07:10:59 PM
Author Topic: Auto Tool changer from Mach3 to Mach 4  (Read 5775 times)
« on: April 25, 2022, 08:01:42 AM »
I, i was using Mach 3 since 2016, but we hav got a Electric Flash and now my CNC is unusable so i have decided since i need to restart from scratch the computer that was running my Mach 3 that i would do the jump and upgrade to Mach 4, as of now, i managed to make everything work. The only question i have is.... On Mach 3 i was using a custom M6Start.m1s and M6End,m1s macros with auto Tool change code. I would like to know if there is a easy way to convert this code from Mach 3 to Mach 4 so i can still use my auto Tool change??
I have attached bot my script!
Thanx a lot!
Offline Bill_O
  •  615 615
Re: Auto Tool changer from Mach3 to Mach 4
« Reply #1 on: April 25, 2022, 08:40:28 AM »
As far as I know there is no easy way.
They are totally different.
You will need someone to change it for you or do it yourself.
Here is a document if you want to do it yourself to help you get started.
https://www.machsupport.com/forum/index.php?topic=45397.msg289143#msg289143
