Hello Guest it is November 22, 2026, 10:03:18 PM
Author Topic: Homing acceleration in mach3  (Read 49056 times)
« on: April 22, 2022, 11:41:32 AM »
in homing process when home signal activated, the axis must stoped. whats is acceleration of this stop?
when I set axis acceleration  to low value for example 80 mm/s2  ,  jog moving is very smooth but when do homing the axis stopping hard...
in config>home/limit   can just speed of homing. what is acceleration homing?
Re: Homing acceleration in mach3
« Reply #1 on: April 22, 2022, 03:47:41 PM »
Since the point of homing is to find the limit switch and the machine doesn't know where that is, deceleration is not possible only a hard stop.  The homing speed is usually set to a few percent of the normal jog speed to minimise the overrun.
« Reply #2 on: April 23, 2022, 02:20:23 AM »
Hi JohnHaine
You are right. hard stop Avoid crash axis and improve position error.
but beter is home stop acceleration should be selectable.
thanks and regards
« Reply #3 on: April 23, 2022, 02:34:20 AM »
How would you know when to start decelerating?
« Reply #4 on: April 23, 2022, 03:43:59 AM »
when I set axis acceleration  to low value for example 80 mm/s2  ,  jog moving is very smooth.  but when do homing the axis stopping hard...
Due to very low acceleration, it is visible to the eye!
« Reply #5 on: April 23, 2022, 04:20:50 AM »
Go to config\homing/limits\ and see what speed% is set in the RH column.  The default in Mach3 is 20%, IIRC on my machines I have set it to 5%.  I think this multiplier works on both the homing speed and acceleration.
Again, how on earth can the machine anticipate when home will be reached when the object of homing is to find that point!  Usually there should be a slight overrun possible on the home switch so the overrun doesn't cause lost steps.
« Reply #6 on: April 23, 2022, 07:12:02 AM »
I do not think homing acceleration is a percentage of acceleration axis. Based on what happens and is seen with the eye!
It can set zero the machin cordinate as soon as the microswitch is activated then slow down at the deceleration. it cause a difference between home switch point  and stopping point. This is not a problem. This will not cause the microswitch to break. This could be selectable.
thanks
« Reply #7 on: April 23, 2022, 08:54:00 AM »
Have you tried changing the homing speed setting?
« Reply #8 on: April 23, 2022, 11:09:13 PM »
Yes sure
« Reply #9 on: April 23, 2022, 11:36:01 PM »
Hi JohnHaine
I repeat test on another mach3 machine with lpt board (mach3 parallel). After the switch is activated, the axis acceleration is very smooth to stop.
first test on china mach3 board that have plugin for connect to board (mkx-et). its not standard mach board.
sorry for incorrect information in first.
thanks
