Hello Guest it is September 28, 2026, 08:24:46 AM
Author Topic: How do I mill a Perfect Circle?  (Read 20279 times)
« on: April 21, 2022, 07:57:29 AM »
Hello all.
I have a newly built CNC machine. I am happy that it is functional.
I have done Automatic Calibration on all 3 axis and they are perfect.
Currently, I am doing test runs to see that it mills with acceptable accuracy.
Whenever I mill a Circle, the end result is an elongated 'circle'. See attached image. (Each of the 'circles' in the image, is the result of a different mill test.)
I have tried playing around with the Velocity and Acceleration settings in Mach 3 but the situation is not improving.
What might be the problem?  Please help.
« Last Edit: April 21, 2022, 08:14:11 AM by Uzito »
Re: How do I mill a Perfect Circle?
« Reply #1 on: April 21, 2022, 09:49:56 AM »
Clearly not actually properly calibrated and possibly losing steps. Do the settings as a result of the autocalibration correspond to calculations?
« Reply #2 on: April 21, 2022, 10:09:43 AM »
I have not done calculations to counter check the AutoCalibration results. I will need to do the maths and see. Thanks John.
Anyone else with a different view and/or solution?
« Reply #3 on: April 21, 2022, 11:35:45 AM »
It's very straightforward if you know the screw pitch, stepper-to-screw gearing, steps per rev (usually 200) and microstep ratio.  See the Mach manual.
Also try some back-and-forth moves from 0 to 100mm back to 0 say and make sure it always returns exactly to zero to check for lost steps.  Do you have a dial indicator for assessing exact stop position?
« Reply #4 on: April 21, 2022, 12:50:54 PM »
Oh, and you may have backlash...
