Hello Guest it is September 28, 2026, 10:26:09 AM
Author Topic: X axis drift  (Read 15483 times)
X axis drift
« on: April 17, 2022, 10:29:02 AM »
I have a head scratcher. I was getting skewed layer passes and have gone thru the usual suspects(belts, pulleys,& hardware). I removed the motor marked the pulley and still have the following issue. If I run a looping program moving the x axis only a distance of 20mm then return to 0 cycling thru this 20 times. . At the end of the run the stop position will actually be at -0.38mm. If I change this to 100mm at 50 cycles I still stop at -0.38 . If I run a single cycle of 1000mm and return to zero I am dead nuts. looking at ideas on how to isolate this drift. I have the pulse duration for the directions signal and pulse signals set to 5 in the motor tuning screen
Offline TPS
  •  2,627 2,627
Re: X axis drift
« Reply #1 on: April 19, 2022, 12:54:26 AM »
what is your setting Step's/per for this axis?
