Hello Guest it is November 22, 2026, 02:49:04 PM
Author Topic: Next line of gcode executing from file before spindle is up at new position  (Read 6980 times)
Mach4 4.2.0.4612
ESS V278.1
C25XP BOB
I'm having an issue where the next line of GCode being executed from a file is happening before the previous line (moving x up out of the way) is completed.
I understood that the command to move the y axis would not happen until the command to move the x axis up out of the way was complete.
I did modify the gcode to move the x asis up .5 higher and that resolved the issue, but looking for better understanding of the correct way to do this.
Is it necessary to insert a delay for this to work properly?
Here is a piece of the GCode
g1 x-.5 F200
g1 x .5
g1 y1.0
g1 x-.5
g1 x.5
g1 y2.0
g1 x-.5
g1 x.5
g1 y3.0
Your code should include a G61 command for Exact Stop before the line of code that must complete before the next line starts. Then include a G64 after that move to allow resuming Constant Velocity mode if desired.
Steve Stallings
www.PMDX.com
That fixed it.
Thanks!!
