Hello
Guest
it is
November 08, 2026, 02:29:17 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
What conditions set the ALARM signal
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: What conditions set the ALARM signal (Read 7167 times)
RecceDG
135
on:
April 13, 2022, 11:12:41 AM »
I have a light tied to the ALARM signal, but nowhere in the docs can I find what conditions set that signal.
So - what sounds the ALARM?
Logged
SwiftyJ
233
Re: What conditions set the ALARM signal
Reply #1 on:
April 14, 2022, 10:49:22 AM »
Using mc.mcCntlMacroAlarm activates the Alarm output. I believe writing to #3000 should also produce an alarm but I can't get it to work
Logged
RecceDG
135
Reply #2 on:
April 19, 2022, 08:03:38 AM »
So nothing native to Mach sets that signal? Limit switches? Loss of position info? EStop?
Shouldn't that signal be set by anything that takes Mach out of the ENABLED state?
Logged
SwiftyJ
233
Reply #3 on:
April 19, 2022, 02:53:14 PM »
Not that I am aware of. If you want it to function like that just set the alarm signal in the signal library when the output for machine enable signal turns off. That’s the great thing about Mach, you can pretty much make it do what you want
Logged
KatzYaakov
600
Reply #4 on:
April 21, 2022, 07:42:55 AM »
i add register for such
and some event that raise up the register
then in any M function before any action( special force output)i Check this registry value
and if...
then return
Logged
Print
Pages:
1
Go Up
« previous
next »
