Hello Guest it is October 24, 2026, 08:47:22 PM
Author Topic: Mach 4 inputs and macros  (Read 5712 times)
« on: April 09, 2022, 03:22:07 PM »
I have some pneumatic cylinders that I am using for easy material locating. I would like to connect the sensors on these cylinders to Mach in such a way that at the beginning of any program there would be a check to see if the cylinders are retracted before allowing the machine to progress.
Is this something that is possible simply through macros?
Re: Mach 4 inputs and macros
« Reply #1 on: April 09, 2022, 09:22:45 PM »
sure its exactly macro uses
you just must put in yours pp that M  function on program header
