Hello Guest it is November 13, 2026, 09:23:57 PM
Author Topic: Mach3 MDI feed rate is very very much slower than Step per unit feed rate  (Read 27945 times)
If anyone could help me.
I have reached the stage of running Gcode commands using the MDI input
i have set up the step per unit and the distance moved and feed rate is all good
My problem is when i select the MDI screen and enter X10, the cnc moves my X axis so slow i could make a coffee and drink it by the time it reaches +10 in the X axis DRO box and moves the actual X axis on the cnc 10mm.
can someone please tell me what am i doing wrong.
Kera
« Last Edit: March 31, 2022, 05:01:01 PM by Graham Waterworth »
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
If you are using mm then on a mill you would enter G01 X10. F100. so the feed is set to 100mm a minute.
Thank you, thank you, thank you
Kera
