Hello Guest it is October 22, 2026, 08:41:29 PM
Author Topic: Using Lua to send commands to Galil  (Read 10999 times)
« on: March 28, 2022, 10:14:13 AM »
Is there a way to send a command to the Galil through Lua? I tried using the "DMC4020/Command" register, but that register does not seem to be for relaying commands to the Galil, and there is no other register I can see in the Galil registers.
I'm trying to initiate a homing/initialization routine on startup of Mach4 (to find the index of both axes), but I want a dialog box to prompt the user before motion begins, so using the built-in Galil "startup" or "before profiled move" settings doesn't really work for us.
