Hello Guest it is October 04, 2026, 09:55:45 PM
Author Topic: Bad Character  (Read 18750 times)
Bad Character
« on: March 16, 2022, 09:50:20 AM »
New to Mach 3 and using with a plasma table.  When trying to load a G- code we get this error message. We have tried multiple drawings, and drawings that were already saved in the computer with the machine. The first week we got it were able to get it to work and now this error.  Any help is appreciated.
  •  9,374 9,374
Re: Bad Character
« Reply #1 on: March 16, 2022, 06:06:26 PM »
Looks like you are trying to load a  .dxf  file into Mach3.
You should be loading a text file typically with the file extention *.tap, *.nc, *.ncc or *.txt
Re: Bad Character
« Reply #2 on: March 17, 2022, 08:46:14 AM »
Someone else said that also.  But we have verified its saved as .tap in sheet cam with multiple drawings, and still get the same result.  What else could cause this?
  •  9,374 9,374
Re: Bad Character
« Reply #3 on: March 17, 2022, 10:15:09 AM »
Your first screen shot clearly shows the file loaded into Mach3 as being test1.dxf
Offline TPS
  •  2,627 2,627
Re: Bad Character
« Reply #4 on: March 18, 2022, 02:50:40 AM »
here:
Re: Bad Character
« Reply #5 on: March 18, 2022, 12:10:26 PM »
We got it figured out , thanks for the help!  We are still learning.
