Hello
Guest
it is
November 19, 2026, 12:59:55 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
New to everything: lines after G04 does not load into Mach3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: New to everything: lines after G04 does not load into Mach3 (Read 15354 times)
IzzyZee
2
on:
March 15, 2022, 11:11:25 AM »
Hello! I'm using the Mach3 demo to learn how to do G-codes.
I loaded 3 lines of G codes:
G0 X10 Y10
G4 P1
G0 X10
However, only the first 2 lines were successfully loaded. Why is the third line omitted?
Any help is appreciated, thank you!
- Izzy
Logged
Tweakie.CNC
9,377
Super Kitty
Re: New to everything: lines after G04 does not load into Mach3
Reply #1 on:
March 15, 2022, 04:13:14 PM »
It's perhaps odd but you need a CR after the last line of Gcode.
A common method to ensure this is to place a
symbol as the last line of the Gcode file.
Logged
IzzyZee
2
Reply #2 on:
March 17, 2022, 03:17:17 PM »
Ah, this helps. Thanks a lot!
Logged
Print
Pages:
1
Go Up
« previous
next »
