Hello Guest it is November 13, 2026, 05:30:26 PM
Author Topic: Huanyang settings help  (Read 24606 times)
Offline Ts
  •  11 11
« on: March 14, 2022, 05:33:34 PM »
I purchased a Used cnc router it was all disassembled When I got it I have it re-assembled and I am trying to get it up and running I have it to the point now where the servo motors are moving an XYZ and I’m trying to get the spindle to operate it has the Huanyang 220v 2.2kw vfd I am using the Mach3 software and I have it to the point where I can turn the spindle off and on with Mach3 but I cannot control the speed I have read some of the other post and tried some of those settings but have had no success any help would be greatly appreciated
Re: Huanyang settings help
« Reply #1 on: March 18, 2022, 05:08:57 PM »
Without knowing more about the hardware you have it's hard to advise.
Offline Ts
  •  11 11
« Reply #2 on: March 19, 2022, 10:25:32 AM »
need help getting Mach3 to control the spindle here’s what I have I have
 warp 9ESS
c35s Break Out Board
c15 dual relay board
c41 variable speed control
I bought this as a project but didn’t get a computer with it so I’m basically starting from scratch and I have no idea why it’s wired the way it is I’m starting to trace wires now to see what the previous owner has done on the VFD he has a wire on the FOR post the DCM the ACM and the V1I would post pictures but for some reason I cannot on this form board
  •  9,377 9,377
« Reply #3 on: March 20, 2022, 01:44:22 AM »
Hi Ts,
This thread explains how to post attachments / pictures to the forum;  https://www.machsupport.com/forum/index.php?topic=24585.msg173822#msg173822
Hope this helps.
« Reply #4 on: March 20, 2022, 05:27:03 AM »
I don't understand what you mean by "the VFD he has a wire on the FOR post the DCM the ACM and the V1I ".  If the C41 is the device from CNC4PC then the manual is here:
https://www.cnc4pc.com/pub/media/productattachments/files/c41s-r1.1_user_manual_v1.pdf
With that and the Mac3 manual from NFS you should be able to work it out.
