Hello Guest it is October 21, 2026, 01:37:45 PM
Author Topic: Superimposing an out of bounds axis on the Z axis in Mach4 Plasma  (Read 6813 times)
I think I understand that the OB axis motor has the same setting and the Z axis motor and the OB axis can be controlled with jog commands but how is the OB axis superimposed on the Z axis?
Thanks for any explanation or coding examples.
« Last Edit: March 09, 2022, 08:39:13 AM by Tony Bullard »
Re: Superimposing an out of bounds axis on the Z axis in Mach4 Plasma
« Reply #1 on: March 09, 2022, 09:19:59 PM »
I don't think an OB axis can be superimposed exactly. My understanding is that "Axis Overload' is employed. Thus tyhe Z axis motor is controlled by the Mach normally
but the 'overload component' adds or subtract a few steps to the Z axis.
Try searching for overload axis.
« Reply #2 on: March 10, 2022, 07:30:53 AM »
Thank you Craig and that explains it well to to me.
It lead me to Axis Override. I setup a button to test the OB6 axis override of  the Z axis. It woks well with this code:
Code: [Select]
                --in button script
--left button down script
-- Set the axis 6 to be the override axis for the Z axis.
mc.mcAxisSetOverrideAxis(inst, mc.AXIS6, mc.AXIS2);
-- Set the Z axis jog accel percentage to 25%.
rc = mc.mcJogSetAccel(inst, mc.AXIS6, 25);
-- Set the jog rate to 20% of the Z axis maximum velocity.
        rc = mc.mcJogSetRate(inst, mc.AXIS6,20)
        -- Start Z axis jogging in positive direction
rc = mc.mcJogVelocityStart(inst, mc.AXIS6, 1);
--in button script
--left button up script
mc.mcJogVelocityStop(inst, mc.AXIS6); -- Stop the axis.
-- Remove axis 6 from the Z axis.
mc.mcAxisRemoveOverrideAxis( inst, mc.AXIS6, mc.AXIS2 );
You are a great asset to this forum. Thank you again.
Tony
