Hello Guest it is October 21, 2026, 08:23:50 PM
Author Topic: changing coordinates systems during tool change  (Read 8383 times)
« on: March 06, 2022, 02:59:07 PM »
My tool change scripts are writen in inches. When I have a file in MM It messes up the tool change script.
When the gcode file is using mm and switches the coordinates to mm, what  do I need to add to my tool change script to switch to inches at start of script and switch back to mm at the end of the script?
Offline Bill_O
  •  615 615
Re: changing coordinates systems during tool change
« Reply #1 on: March 07, 2022, 10:09:48 AM »
It will take a little coding but this is basically what you need to do.
get current units
mcCntlGetUnitsCurrent
if G20 for inch
do tool change
if G21 for mm
set units to G20
do tool change
set units back to G21
« Reply #2 on: March 07, 2022, 10:49:45 AM »
get current units
if G20 for inch
do tool change
if G21 for mm
set units to G20
do tool change
This is great mcCntlGetUnitsCurrent was what I was looking for.
How is this used would I just do:
local units = rc.mcCntlGetUnitsCurrent(inst)
mc.mcCntlGcodeExecuteWait(inst, "G20")
do tool change stuff
if (units = "mm") then
    mc.mcCntlGcodeExecuteWait(inst, "G21")
end
Is there any documentation of all the mc commands (mcCntlGcodeExecuteWait, mcCntlGetUnitsCurrent, etc.). I have not seen a document with them all listed. I would have expected them to be in the lua scripting manual found here: https://www.machsupport.com/wp-content/uploads/2014/05/Mach4%20Scripting%20Manual.pdf
Offline Bill_O
  •  615 615
« Reply #3 on: March 07, 2022, 12:27:49 PM »
here is where you can find all the mc calls
C:\Mach4Hobby\Docs\Mach4CoreAPI.chm
Offline Bill_O
  •  615 615
« Reply #4 on: March 07, 2022, 12:29:10 PM »
also this might be helpful if you have never done code in lua
https://www.machsupport.com/forum/index.php?topic=45397.0
