Hello Guest it is October 20, 2026, 08:34:19 PM
Author Topic: Homing help  (Read 21913 times)
Offline kd
  •  3 3
Homing help
« on: February 28, 2022, 01:27:25 PM »
I can't seem to figure out how to home my machine. Been searching for a couple of weeks. If I understand it correctly, you are supposed to move the head to the zero position found using limit switches, then zero it out. Then when I start something new, I'm supposed to hit REF ALL HOME and the machine homes itself by moving to the zero position. All I get is that it rezeroes at the current position without moving. It will not home itself. I've tried many things without success. Switch bounce, clean XML file - nothing. Am I misunderstanding the process? How am I supposed to home it? Is there another button? BTW, if I do G28.1 X2, it will go to the zero position.
Offline kd
  •  3 3
Re: Homing help
« Reply #1 on: February 28, 2022, 01:55:19 PM »
Found it. Didn't set X home switch, etc. Finally noticed a reference to that in the manual (2 weeks later) - ugh.
