Hello Guest it is September 11, 2026, 02:32:07 AM
Author Topic: machscreen .. adding dro and script from button??  (Read 39414 times)
« on: February 20, 2022, 09:12:23 AM »
hi!
2 questions :)
i playing with my mach3 and machscreen..
1.
i have add a button to my screen.
i wrote a vbscript and save them.in the macro folder.
name of the script is HomeTurret.
now i want to load this script as file when i hit the button.
if i change something on the script i dont want to add the script again with machscreen.
is this possible??? can someone help me?
2.
when i do a toolchange my turret jogs to x5 z55.
this values are named wzwx and wzwz
i add 2 dro to my screen.
i wish that the dros show me wzwx (5) and wzwz (55).
and i want.. if i change the value in the dro.. that is set wzwx and wzwz to this.
example : in the dro i put in 10 and 60.
then the machine jogs to x10 and z60.
its to set a toolchange position.
is this possible?!
thanks
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: machscreen .. adding dro and script from button??
« Reply #1 on: February 20, 2022, 11:23:07 AM »
You add the following line to the execute script section of the button property
Filepath = "\mach3\macros\Mach3Mill\YOUR_MACRO"
RunScript(Filepath)
Use G53 values for the tool change position.  To get these click the machine DRO button, these do not change when you reset the fixture offsets.
« Last Edit: February 20, 2022, 11:25:47 AM by Graham Waterworth »
« Reply #2 on: February 20, 2022, 11:25:00 AM »
nice!
works.. perfect... and what about the dro??? is this possible????
thanks!!
Offline TPS
  •  2,627 2,627
« Reply #3 on: April 22, 2022, 12:17:42 PM »
for example your OEMDro's are:
wzwx = OEMDro(1200) and wzwz = OEMDro(1201)
the VBCode would be:
Code: [Select]
  Code ("G1 X" &GetOEMDro(1200) &" Z" &GetOEMDro(1201) &" F123")
btw.
https://www.machsupport.com/wp-content/uploads/2013/02/Mach3_V3.x_Macro_Prog_Ref.pdf
is allways good to have
« Reply #4 on: April 23, 2022, 06:16:31 AM »
thanks!
but why g1?!
if i am at home i would check it.
Offline TPS
  •  2,627 2,627
« Reply #5 on: April 23, 2022, 06:21:10 AM »
you can also use a G0
« Reply #6 on: April 23, 2022, 06:27:55 AM »
wzwx and wzwz is to set the position.
not to go to the position.
i want to use the dro wzwx and wzwz to set the position which is used when g53 is entered.. or better... when i call t0101 or something what make a toolchange.
hope you understand?
thanks
Offline TPS
  •  2,627 2,627
« Reply #7 on: April 24, 2022, 02:56:48 AM »
for toolchange normaly M6Start.M1S and depending on the way you do your toolchange M6End.M1S
are used.
do at the begin of M6Start a
Code: [Select]
  Code ("G53 G1 X" &GetOEMDro(1200) &" Z" &GetOEMDro(1201) &" F123")
will allways bring the machine first to a tool change position.
