Hello Guest it is October 25, 2026, 01:10:51 AM
Author Topic: Z won't raise above 2"  (Read 7132 times)
« on: February 16, 2022, 01:46:35 PM »
Hi, I'm just getting Mach4 set up on my older 4896Pro.  It doesn't have Z sensors, so I went into ESS Config > Homing and turned off the Z and reset the X & Y to priority one.  It Homes XY flawlessly.  But now the Z won't jog more than 2" high.  Any ideas?
Thanks!
Avid CNC 4896Pro (rack & pinion), ESS, CRP500, Nema 23, Mach3--updating to Mach4
plus OPT Laser
Re: Z won't raise above 2"
« Reply #1 on: February 16, 2022, 02:05:39 PM »
what software are using, Mach3 or Mach4? I ask because that sounds like 'SafeZ' which is a feature and setting of Mach3 bit does not have a direct equivalent in Mach4.
« Reply #2 on: February 16, 2022, 02:16:00 PM »
This is with Mach4.
plus OPT Laser
« Reply #3 on: February 16, 2022, 03:06:47 PM »
well the only thing I can think of is SoftLimits. Are they active?
