Hello Guest it is October 20, 2026, 03:02:06 PM
Author Topic: Mach3 Threading with Gear head lathe  (Read 56067 times)
« on: February 13, 2022, 08:06:55 PM »
Hello,
I'm sure there is an answer buried in the 6 pages and 1000s of comments in threads from days past to my question but after some brief searching I got nothing.
Attempting to thread on my gear head lathe (no spindle control with Mach3, and not spindle feedback).
Not going well.
The X depth seems to work, but Z movement is way out of wack and the cut is all over hahaha.
I tried slower and tried faster.
Here is video @ 90RPM on the lathe.
(The Zaxis set up is pretty heavy, can't get much for speed out of the 1700 oz-in motor).
https://youtube.com/shorts/vh8VLeU9f_4?feature=share
Photos attached.
Thanks!
Kyle
Re: Mach3 Threading with Gear head lathe
« Reply #1 on: February 13, 2022, 10:01:12 PM »
threading requires that the spindle is synchronised to the Z axis movement, its fundamental to be able to take multiple cuts of a thread to get it to its
final depth.
Mach3 REQUIRES a single pulse per rev index signal. If you do not have one you'll have to provide one. Mach3 is also expects and demands that your spindle
be a stable speed, neither getting faster or slower as the cut progresses. If your spindle cannot stay stable then single point lathe threading with Mach3 is going
to be a disaster.
« Reply #2 on: February 13, 2022, 10:20:28 PM »
final depth.
to be a disaster.
Yeah put a call into a friend.
I do have a cherry hall sensor. But could never get it to work with the break out board! Haha.
It's 3 wires, and 12V.
Any ideas on getting it going with a DB25 1R5AM board?
Thanks Craig!
« Reply #3 on: February 13, 2022, 10:38:41 PM »
I have no idea what that board is. Do you have a circuit diagram for its inputs?
« Reply #4 on: February 13, 2022, 11:03:11 PM »
I Have this.
From what I know the brown wire is power to the 1-10V port on the board. Then the blue goes to a normal port and black goes to ground? Then the port needs to be assigned to the spindle reading but it never did give me any feedback before (I didn't have a smooth stepper before and had a ton of interference from the parallel ports).
I dont think the board has any pull up or down setting?
Thanks Craig!
« Reply #5 on: February 13, 2022, 11:42:34 PM »
Okay,
Cherry hall sensor is wired on.
I have it set to port 11 (blue wire) which is a signal input.
Red is in the 0-10V pin and black to ground.
I have a power source going to the 12-24V and ground as well.
In mach I set port 11 to index and I have a green light in diagnostics now.
Is this correct for just indexing the spindle for threading?
Any way I know to test this? It doesn't show a spindle speed when I turn on the spindle and tried typing M3.
(Lathe is gear box so I can't control the spindle from computer).
Photos attached.
Kyle
« Reply #6 on: February 13, 2022, 11:51:04 PM »
Mach doe not need to cotrol the spindle but it does need an index signal from it.
The manual for your board is a joke.....there is no information about the electrical properties of the inputs, and without that
there is no way to get the index signal working.
« Reply #7 on: February 13, 2022, 11:57:25 PM »
Haha!
Well that makes me feel like stupid hahahaha.
Okay,
Well, I do have the C10 board but it's only a 5V?
I'm open to buying a different sensor (this cherry hall come with the lathe as is). Any ideas on something Craig?
The manual for the C10 is attached.
Kyle
« Reply #8 on: February 14, 2022, 12:27:42 AM »
I bought a hall proximity sensor off Amazon.
Hopefully it does the trick.
Not even sure this current one works haha, for 30 bucks I'll try another. I may splice the power from the plug direct to the sensor and not run through the board other then the signal wire?
If that makes sense and that way I know the sensor is powered properly.
Kyle
Offline TPS
  •  2,627 2,627
« Reply #9 on: February 14, 2022, 12:27:50 AM »
just an idea, have you enabled
Config -> Ports&Pins -> Spindle Setup -> Use Spindle Feedback in Sync Modes
Config -> Ports&Pins -> Spindle Setup -> Spindle Speed Averraging
