Hello Guest it is October 25, 2026, 03:15:56 AM
Author Topic: Mach4 opens opens windowed but thinks it is maximized  (Read 5675 times)
Offline Azalin
  •  191 191
« on: February 11, 2022, 01:55:40 PM »
Every time I open Mach4 it opens as windowed as you see in the attached image. However the maximize/restore button on the top right corner is in restore state so it is actually maximized (confusing?). When I click that button Mach4 tries to make itself windowed. Then the button change to maximize state and when I click it it maximizes (truly maximized).
I always exit Mach4 maximized and expect it to start maximized.
I know its weird. Does anyone have the same issue? Is there a way to fix it?
Offline Azalin
  •  191 191
Re: Mach4 opens opens windowed but thinks it is maximized
« Reply #1 on: February 11, 2022, 04:42:26 PM »
I found the problem. Windows display scaling causes this.
