Hello Guest it is November 22, 2026, 09:17:46 PM
Author Topic: help pls yoocnc with mach3 usb  (Read 25954 times)
« on: February 10, 2022, 11:12:51 AM »
Hi, I have a yoocnc 6040z 4 axis, I would like to connect this to my laptop windows 10 using mach 3. The usb card has a number on it Y0C-USBM3-V2.2. I have just purchased this machine and have no idea how to get it to connect to the laptop. Can some one give me the usb driver needed for the plug ins folder and if possible do you have an xml file to get this working please. I currently have a 3040t  parallel port machine which I use with mach 3 no probs. many thanks.
Re: help pls yoocnc with mach3 usb
« Reply #1 on: February 13, 2022, 09:25:45 AM »
You might check out some of the links in this other thread.
https://www.cnczone.com/forums/mach-software-artsoft-software-/357060-cnc-software.html
« Reply #2 on: February 14, 2022, 12:13:29 AM »
thank you, I have ordered another motion control card for mach3, lets see how that goes.
« Reply #3 on: October 18, 2022, 06:10:27 AM »
Hi, I have the same YOOCNC 6040Z 4-axis machine, but can't get the spindle to work. If all works at your end, could you share your Mach3 settings? Output, input, spindle, … Screenshots would be great. I'm running out of things to try and already spent hours and hours figuring it out. Thanks.
