Hello Guest it is October 20, 2026, 10:48:49 PM
Author Topic: Mach3 Motor Tuning wont save  (Read 22631 times)
« on: February 07, 2022, 09:31:57 AM »
Problems with saving step and dir pulse in mach 3 motor tuning , each time i save all 3 axis and each time returns to zero , no matter how many times i cange and shave axis settings and then save settings it goes straight back to zero , running it on windows 10 and this has only just started happening.
cheers
Re: Mach3 Motor Tuning wont save
« Reply #1 on: February 17, 2022, 02:23:04 PM »
Look in the motor outputs to make sure they are enabled and have pins and port number specified. If it just started doing this, then see if you can recover the XML from a previous run.
