Hello Guest it is November 22, 2026, 02:02:39 PM
Author Topic: Mach4 Motor axis trouble shooting  (Read 5346 times)
« on: February 07, 2022, 08:14:41 AM »
Hi Guys,
Just installed Mach4 today with full licensed software, i managed to get everything installed including Mach4 USB motion controller. I have a couple of issues with regards the motor config and signals. I have set the pulse for the motors (1062) gives me 1-1 ratio for direct connection. However i cannot get Z and A (rotary) axis to work, X and Y are working fine. I tried plugging the X motor into the Z just to rule out bad connection etc. Nothing happens. i am not using limit switches on this set up as it is a test rig for something other than a CNC machine. i would very much appreciate any help on this . Thanks
