Hello Guest it is October 25, 2026, 07:34:39 AM
Author Topic: mach3 turn postprocessor for fusion360? (turning,threading g76)  (Read 24506 times)
« on: February 03, 2022, 05:18:21 PM »
hi! i look arround cad cam and want to know if there a postprocessor is avaible to use it dith fusion360 and mach3.
i think biggest problem is threading with g76.
has someone a working pp?
thanks!
Re: mach3 turn postprocessor for fusion360? (turning,threading g76)
« Reply #1 on: February 03, 2022, 05:55:52 PM »
It's been a few years since I used Fusion 360 lathe. It does provide good code for use by Mach3.
If my memory is correct,  from one of the pull downs you can access /  download load different post processors.
Just for reference  you may find the CPS in the following directory of your PC:
C:\Users\user\AppData\Local\Autodesk\webdeploy\production\890691bd91ea0296c1b94572fdc7dda4ba2e48f0\Applications\CAM360\Data\Posts
You can edit them to customise, BUT, you better know what your doing. There was a video on how to edit them, about 1 hour long, that I watched and educated me on how to make changes.
Have Fun,
« Reply #2 on: February 04, 2022, 12:13:04 AM »
good morning, i thank you.
another question.
if there a programm available which works direct with mach3?
I think the biggest problem is g2 g3 and css and threading or?
thanks
« Reply #3 on: February 04, 2022, 05:24:02 PM »
Use the Wizards, Lazycam, Lazyturn, Meshcam, Wrapper, Fusion 360, Dolphin / Partmaster  .....whatever gets the job done the easiest for what
for what I want to do. Last would be hand writing the code.
Try Free Cad and other programs .........................
