Hello Guest it is November 10, 2026, 01:51:49 AM
Author Topic: Variable speed controller with modbus communication for AC motor  (Read 19103 times)
I am creating a specialized lathe running four steppers on two cross slides.I have an AC motor turning the lathe spindle that is hooked up to a variable speed controller, specifically a GS2 from Automation Direct. According to the specifications, this unit has "RS-232/485 Modbus communications up to 38.4 Kbps." Can I somehow use this feature so I can controll the spindle speed (via the controller and AC motor) from Mach software?
Re: Variable speed controller with modbus communication for AC motor
« Reply #1 on: October 22, 2007, 05:36:07 AM »
Yes you can. If you set up the coms in Mach to suit your VFD, then write a macropump, it should work fine.
As I don't have a VFD, I haven't done it myself.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
« Reply #2 on: October 22, 2007, 10:42:45 AM »
Yup, Peter is right. Also, might want to look at Brains for setting it up.
