Hello Guest it is October 20, 2026, 06:45:14 PM
Author Topic: E-stop requested comes up when cutting a circular pocket.  (Read 24172 times)
Offline dlang
  •  10 10
« on: January 18, 2022, 10:14:04 PM »
First time ever had this issue come up. Milling a pocket that is round. Cutting just fine and then the cut just stops cutting for no reason . On the mach3 screen it says emergency mode active,external e-stop requested . Can't restart program . Have to reset and start program from start and then the program runs the whole program all the way through. Sometime when the program runs all the way thru,then I run the same program again and it stops the same as describe above. Not sure what to look for what is wrong.
 Had issues when I added a led light on the mach3 screen for the probe pickup . The light for the z height pickup would not light. So I switched the wire around with the e-stop and then the z height pickup worked.Dont know why this worked either .
   Thanks Dan
