Hello Guest it is October 22, 2026, 01:19:35 AM
Author Topic: Turn off mist/flood on stop/estop  (Read 6950 times)
« on: January 11, 2022, 10:00:00 AM »
Is there a setting in Mach4 that will turn off Mist/Flood (m9) whenever a Stop or EStop is issued or do I need to modify something in the screenload script?
TIA
RT
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Turn off mist/flood on stop/estop
« Reply #1 on: January 11, 2022, 01:33:08 PM »
You could just add it to the siglib to look out for the estop and then turn off what you want off and same add the code to the stop signal or button if easier.
DazTheGas
« Reply #2 on: January 11, 2022, 07:31:45 PM »
how about using:
Code: [Select]
LUA Syntax:
cycle, rc = mc.mcCntlIsInCycle(
number mInst)
Description:
Used to see if a G code file is running.
in the PLC script. If the machine is 'InCycle' then leave the Mist/Flood output as is and if its not 'InCycle' then turn Mist/Flood off.
« Reply #3 on: January 13, 2022, 01:01:50 PM »
Thanks guys I'll give it a try later.
RT
« Reply #4 on: January 14, 2022, 01:41:30 AM »
pmc its easy place
