Hello Guest it is October 20, 2026, 08:35:57 PM
Author Topic: no keyboard rapid after led install on mach3 screen  (Read 23239 times)
Offline dlang
  •  10 10
« on: January 09, 2022, 02:57:26 PM »
Installed led on mach3 screen to show touch probe for tool bit pick up. After installing led the light seemed to work fine. But the keyboard arrows dont move the machine at a rapid manual move. not sure what I have wrong. If I do a manual move in mdi doing a gox1. it moves in a rapid move just fine. I can move the machine with the key board arrow but they move only at 20 ipm instead of 100 ipm .
     Thanks for any help . Dan
Re: no keyboard rapid after led install on mach3 screen
« Reply #1 on: January 12, 2022, 04:46:05 AM »
Hi Dan
did you add or change a page?
is this behavior on every page of your screenset?
Klaus
The brain isn't a soap, it doesn't shrink when used.
Offline dlang
  •  10 10
« Reply #2 on: January 13, 2022, 11:03:45 AM »
yes this happened in all screens.
Dont know why but when i went into ports and pin ,went into inputs and turned enable on and off on some of the over travel switches and for what ever reason. the rapid move came back. not sure what changed by adding the led light did . but for now it all works. I dont really under stand why this worked.
   Thanks for the help. Dan
