Hello Guest it is October 21, 2026, 12:47:23 PM
Author Topic: 4th Axis feed problem, need to increase feed rate  (Read 9877 times)
« on: October 20, 2007, 06:53:30 AM »
I'm still running Mach 2 as my laptop doesn't have the capacity for Mach 3. That being said, what I have done is substituted the A axis for the Y axis in my code simply by doing a search & replace with a text editor. I believe I can accomplish the same in Mach by slaving an axis but haven't read the manual on that. Anyway, the problem I'm faced with is the mechanical difference between the A axis and the XY axis's results in a substancial feed feed rate difference. I need to determine a way to make the actual feed rate the same for  the A axis as it is for the others. Suggestions?
Re: 4th Axis feed problem, need to increase feed rate
« Reply #1 on: October 22, 2007, 09:06:09 AM »
Well, I figured out another means to work around the problem and essentially make the A axis act as a lineal axis, this feed at the same rate as the others.
