Hello Guest it is September 28, 2026, 11:30:40 AM
Author Topic: Commanded Axis exceeds Soft Limits  (Read 15872 times)
« on: December 30, 2021, 09:42:21 AM »
Thanks in advance for any feedback or advice.
I have not been able to run any MDI or Gcode commands as I keep getting the error "Commanded axis exceeds soft limits." I have checked things over and over and I am not commanding even close to the soft limits. I have generally been trying MDI commands starting with G90 G53 to keep things consistant, but I'm starting to believe that the soft limits have been somehow changing to a work offset instead of the machine coordinates.
Even NFS can't figure it out. I have been working on this for weeks sharing screen shots and walk through videos with support.
Just lately they have had me install the demo version of Mach4, and a beta plugin.
The demo version will not talk to the ESS unless I remove all licensed Mach4Hobby files I have previously been using. Still yet, I can only get newly created profiles to talk to the ESS.
I have not taken the time to use a newly created profile and fill in all the configurations and settings to see if it solves the problem.
I am hoping that someone else has dealt with this before and found a solution. Before I go through all of the trouble re-writing all the LUA scripts and all.
Any help, direction and/or advice would be super appreciated.
I'm starting to think going the Mach route was a very bad idea.
