Hello Guest it is November 23, 2026, 04:51:30 AM
Author Topic: No touch off button?  (Read 16686 times)
« on: December 28, 2021, 07:46:21 AM »
Hi all, just trying to get touch off working and just got the digitise led to light in diagnostics using input pin 11 and enable “probe” in ports and pins and was expecting a button to be added after “enabling” (ticking) in ports and pins.
Not sure if probing or touch off is the same thing or different, I’ve seen posts suggesting I can change the behaviour of a button to use a script which could work but I would need the button first?
I’ve have put a couple of images here that shows the config I have which might help https://www.icloud.com/sharedalbum/#B11GhtLJ3JFThs2 most of the stuff I’ve read is mach4 related so unsure if mach3 can even do it.
All I need it to is touch and then back off a pre determined amount and then zero out.
I did read that mach4hobby folder has a document in there but I’m no where need the cnc at the moment so can’t check if my mach3 contains a similar document :(
Is it Possible with mach3?
Rich
Re: No touch off button?
« Reply #1 on: December 28, 2021, 08:08:03 AM »
Actually just found a useful YouTube video, so just need to find a script and I should be golden!
