Hello
Guest
it is
November 19, 2026, 02:06:12 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
Gcode error on line 0
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Gcode error on line 0 (Read 13305 times)
Maury D
3
on:
December 16, 2021, 02:12:17 PM »
Hi everyone .Looking for some help for a brand new nooby to CNC. I have purchased some DXF files from the internet and have tried to load them into Mach 3 . I have tried 2 so far and both give me the same error. It tells me that on line 0 there is a code problem . Since I don't know what the code should look like what should I be looking for? I have attached the G code that was generated by Mach 3. The job is just a small butterfly with no inside cuts. any help would be appreciated
Logged
Maury D
3
Re: Gcode error on line 0
Reply #1 on:
December 16, 2021, 02:29:48 PM »
I should mention further to my last post that the error on line 0 is"Bad Character"
Logged
ZASto
434
Reply #2 on:
December 18, 2021, 01:14:07 AM »
I see no problem with your Gcode.
If I remember correctly, maybe Mach3 went hiwire
as it happened to me on one of my computers.
Try reinstalling Mach3, and do not use spaces in File name. Use at least underscore _
Logged
My personality is who I am.
Maury D
3
Reply #3 on:
December 28, 2021, 12:41:29 PM »
Thanks for the reply. I think you might be right about Mach 3 because every file that I try to bring over from Sheet Cam shows the same code even the pre loaded files where I know the code must be good because I have cut some of them already. We are away from the college until the new year. Is reinstalling Mach 3 a difficult process. I have looked on YOUTube but i'm looking for the most user friendly version.
Logged
ZASto
434
Reply #4 on:
December 28, 2021, 12:52:02 PM »
Reinstalling is easy as 1-2-3
Just back up your profile, if you use default one that you modified, licence file and folder with macros - just in case.
Logged
Print
Pages:
1
Go Up
« previous
next »
