Hello Guest it is October 12, 2026, 02:11:24 AM
Author Topic: [Help] Usb board don't trigger e-stop or home/end switches  (Read 19441 times)
« on: December 09, 2021, 08:58:15 AM »
Hi everyone  :D
Im still trying to finish my build but after some good progress (motor working good, all ports and pins configured) i get stuck trying that this Breakout board recognise when i press the end stops, home or emergency stops...
Everyting is wired like they said, i move the motor and when i press the endstops the motor continue like nothings happen  >:(
This is the board:
It came with a cd with some plugin that is that i already put, and a manual that sais the numbers of ports and pins
I don't have anything more than that. So i suspect that im not geting something.
This is the wiring diagram
Any idea from where to start checking?
Re: [Help] Usb board don't trigger e-stop or home/end switches
« Reply #1 on: March 21, 2022, 01:43:14 AM »
Do you find what it cause that or how it is solved?
