Hello Guest it is October 24, 2026, 04:14:52 PM
Author Topic: Can i enter my own jog increment in Mach4?  (Read 13896 times)
« on: November 28, 2021, 08:55:27 AM »
I am trying to enter my own jog increment in Mach 4. In Mach3 using the MPG Mode, i could edit the default increment, like 1, .01, .001, ect.
However the text box on the jog screen in Mach4 is not editable. So if i want to move the axis 1.35 inches I cant type this increment in and to jog said distance.
Am I missing something?
Re: Can i enter my own jog increment in Mach4?
« Reply #1 on: November 28, 2021, 10:11:41 PM »
yes you can set the increments.
Open the Control plugin and the General Tab, there you can set the increments as you wish.
« Reply #2 on: November 30, 2021, 01:52:55 PM »
Actually I want to change increments on the fly. In Mach 3 that was possible. I don’t want to reset the default jog increments I just want to type in the measurement and move the axis.
« Reply #3 on: November 30, 2021, 02:07:47 PM »
OK....thats new to me. I suspect its possible, go to the properties tab of the jog increment DRO, i think you'll fin the option to edit
the entry in-line. Try it a see.
« Reply #4 on: November 30, 2021, 02:49:35 PM »
If you mean the JOGGING tab? Then the text box with increments? If so , that text box is not editable
« Reply #5 on: November 30, 2021, 03:10:25 PM »
OK, create a another button that asks yo to set a jog increment and then use:
Code: [Select]
LUA Syntax:
rc = mc.mcJogSetInc(
number mInst,
number axisId,
number increment)
Description:
Set the current jog increment for the give axis.
to pass that value to the Jog Increment DRO
« Reply #6 on: November 30, 2021, 03:12:54 PM »
I will try this. Thank you very much!
« Reply #7 on: November 30, 2021, 03:43:06 PM »
I created a new button. Where would I paste this code? Really this is new to me
« Reply #8 on: November 30, 2021, 04:19:57 PM »
in Screen Edit mode go to the Event Properties of the button. There you can attach a script.
The script itself will most probably be in the Screen Load script, how ever when you are developing the code and debugging it I would suggest you make it a macro within
the macros folder of your current profile. This allows you to run the script in a 'sandbox' so you can use all the debugging advantages of the ZeroBrane editor. Only once
you have de-bugged the script would you install it in the screen Load script.
« Reply #9 on: November 30, 2021, 04:33:07 PM »
I will try that. Thanks again
