Hello Guest it is October 24, 2026, 10:24:21 PM
Author Topic: Mach4: Need help with a macro for lathe turret.  (Read 23267 times)
Re: Mach4: Need help with a macro for lathe turret.
« Reply #20 on: December 09, 2021, 11:50:24 PM »
So i got an ethernet switch in, I also got the switch PLC. I have them connected. I have modbus setup in mach4, following along with your other thread. Though i havent made it to writing the actual code for the plc but is it normal to not be able to maintain connection with both the ESS and the PLC? or is this just an issue im going to have with the ESS?
