Hello Guest it is October 24, 2026, 09:07:20 PM
Author Topic: Mach4: Need help with a macro for lathe turret.  (Read 23263 times)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Mach4: Need help with a macro for lathe turret.
« Reply #10 on: December 05, 2021, 09:24:54 PM »
The drawing you posted are too small to read so its hard to tell just what is needed.
If you have a pulse for every tool then that is the one you need to check.
if moving from tool 1 to tool 3 you will have 2 pulses one for tool 2 and 1 for tool 3,  so you need a table of waits.
some thing along the lines of
moves = currenttool - nexttool + 8
if moves = 8 then
  message("tool is already in position")
else
  "unlock turret"
  "start turret running"
  if moves = 1 or moves = 15
    "wait for signal to go low"
    "wait for signal to go high"
  end if
   if moves = 2 or moves = 14
  end if
   if moves = 3 or moves = 13
  end if
   if moves = 4 or moves = 12
  end if
   if moves = 5 or moves = 11
  end if
   if moves = 6 or moves = 10
  end if
   if moves = 7 or moves = 9
  end if
"stop motor"
"check inputs for correct poition"
"lock turret"
"set current tool to next tool"
End
« Last Edit: December 05, 2021, 09:33:03 PM by Graham Waterworth »
« Reply #11 on: December 06, 2021, 08:08:34 AM »
Aaronky; I use the Click PLC all the time here in the shop.  Mostly I put them on machines with Mach4 to handle most of the IO and trivial tasks I don't want to code in Mach4.  I even use the Click for lathe turret tool changes.
Chad Byrd
« Reply #12 on: December 06, 2021, 08:11:49 AM »
OK that's making more sense now. I also posted a link with a better detailed drawing a few post after that. The response time is fairly fast in my opinion. Do you feel this is better and more reliably done with a plc? Or is mach4 and a smoothstepper fully capable?
« Reply #13 on: December 06, 2021, 08:13:37 AM »
Good to know Chad, thanks for your input. Do you feel like the plc and module I posted would be sufficient? The control board and the turret use 24v so it should be compatible I think. Are the click units fairly easy to create the logic for?
« Reply #14 on: December 06, 2021, 08:19:18 AM »
Yes, I always get ethernet, mainly because I use TCP Modbus communication between the Click and Mach4 and it is much faster file transfer.  As long as you only need the 8 in and 6 out that should work.
As far as creating logic.  It is all ladder logic, if you know how to do that then it is fairly straight forward; if not, YouTube is your friend.  The first time I ever used a PLC was to do a tool change on a Hurco VMC; fairly extensive but I got it figured out pretty quick.
On this forum, I'm sure everyone will have their own opinion, use a PLC or just code the tool change.  To me, if you are using a stepper or servo for turret position, I would code it.  If you are using switches, counting mechanism, or some other mechanical way of determining position, I would personally use a PLC because it is easier for me to do.
Chad Byrd
« Reply #15 on: December 06, 2021, 08:29:47 AM »
I think that is the route I'll go. How do you use the another ethernet with mach. Do you have several rj45 inputs? Or a switch?
I have 6inputs and 2 outputs with the toolchanger. How does the plc communicate if I cannot use ethernet? I would need 3 more inputs so a total of 9 so I could tell the plc between those 3 inputs which of the 8 tools to call? Or is that wrong?
« Reply #16 on: December 06, 2021, 08:39:46 AM »
I have a switch that connects the HiCON motion controller and the Click PLC to the computer.
https://www.machsupport.com/forum/index.php?topic=34228.0  This thread is helpful getting modbus communication set up, and I think it has an M6 macro in there as well.
Chad Byrd
« Reply #17 on: December 06, 2021, 10:53:39 AM »
I looked through it briefly, it will be very helpful when I go to set it up. What kind of ethernet switch do you run?
« Reply #18 on: December 06, 2021, 01:48:01 PM »
Can I just use the USB 3.0 instead of the ethernet on the plc?
« Reply #19 on: December 06, 2021, 02:25:01 PM »
I have never used USB PLC so I do not know.  We have had luck with cheap switches off of Amazon or eBay.  I now get the expensive ones from automation direct; I know these won't mess up on me.
Chad Byrd
