Hello Guest it is November 10, 2026, 01:56:30 AM
Author Topic: help macro to call g54 , g55, g56, g57,g58, g59, g60  (Read 17435 times)
« on: November 25, 2021, 11:07:06 PM »
Hello, how are you? I have built a machine that has 7 heads,
I would like to know if you can create a macro that when reading a tool change in g code, the macro calls the offset in the X and Y axes of that tool.
I tried but I don't understand any programming and
I've seen videos of machines doing it but I can't.
I only have this macro M6 star but it does not work well for me
Thank you
attentively
'get new tool number
   newtool = GetSelectedTool()
       'select Offset by toolnumber
       If newtool = 1 Then
           Code "G54"
       Else
           Code "G55"
      End If
        If newtool = 2 Then
           Code "G55"
         Else
           Code "G56"
       End If
        If newtool = 3 Then
           Code "G56"
       Else
           Code "G57"
       End If
« Last Edit: November 25, 2021, 11:09:08 PM by pedropin »
Offline TPS
  •  2,627 2,627
Re: help macro to call g54 , g55, g56, g57,g58, g59, g60
« Reply #1 on: November 26, 2021, 01:43:49 AM »
maybe this is what you are looking for
Code: [Select]
If newtool = 1 Then
Code "G54"
End If
If newtool = 2 Then
Code "G55"
End If
If newtool = 3 Then
Code "G56"
End If
If newtool = 4 Then
Code "G57"
End If
If newtool = 5 Then
Code "G58"
End If
If newtool = 6 Then
Code "G59"
End If
If newtool = 7 Then
Code "G59P7"
End If
Offline TPS
  •  2,627 2,627
« Reply #2 on: November 26, 2021, 01:47:36 AM »
this version will also set new toollength if it is set in tooltable
Code: [Select]
If newtool = 1 Then
Code "G54"
End If
If newtool = 2 Then
Code "G55"
End If
If newtool = 3 Then
Code "G56"
End If
If newtool = 4 Then
Code "G57"
End If
If newtool = 5 Then
Code "G58"
End If
If newtool = 6 Then
Code "G59"
End If
If newtool = 7 Then
Code "G59P7"
End If
SetCurrentTool(newtool)
Code "G43H" 6 newtool
« Reply #3 on: November 26, 2021, 08:23:08 AM »
Thank you very much this is what I need, how good the help of this forum.
why in the last line of the code you write?
  Code "G59P7"
have a good day and thank you again
Offline TPS
  •  2,627 2,627
« Reply #4 on: November 26, 2021, 10:17:46 AM »
if you have a look to config -> fixtures there is no G60 the next after G59 is G59P7.
« Reply #5 on: November 29, 2021, 09:34:46 AM »
ahhh I understood thank you sir
Offline TPS
  •  2,627 2,627
« Reply #6 on: June 16, 2022, 03:05:14 AM »
you mean:
Code: [Select]
Code "G43H" &newtool
it is just to activate tool length compensation
the original code:
Code: [Select]
was faulty the 6 has to be a &
