Hello Guest it is October 20, 2026, 07:41:52 PM
Author Topic: Can two different Mach3 profiles open in two different monitors?  (Read 22168 times)
« on: November 23, 2021, 01:00:20 PM »
Hi!
I'm planning on using one PC with dual monitor support to control both mill and lathe.
Over Windows 10 (using ESS) is it possible to make one profile of mach3 open in one monitor and another profile to open in the other monitor? Not at the same time, sure.
Thanks!
  •  9,374 9,374
Re: Can two different Mach3 profiles open in two different monitors?
« Reply #1 on: November 24, 2021, 12:28:54 AM »
There is no function within Mach3 to select a particular monitor and as far as I am aware Win10 / Win11 currently has no such feature. There are however some third-party software’s (such as DisplayFusion) which should accomplish the task.
