Hello Guest it is October 25, 2026, 12:31:22 AM
Author Topic: Z-axis +/- reversed  (Read 7778 times)
Z-axis +/- reversed
« on: November 17, 2021, 06:18:39 PM »
Hi All, I just installed Mach4 Hobby. My Taig Mill worked perfectly using Mach3 but after installation of Mach4, the Z-axis is reversed. Z+ now moves the head down and Z- the opposite. Has anyone had this problem? Equipment: Taig 5019DSLS mill, UC-100 motion controller, Mach4 Hobby. Thanks in advance.
Re: Z-axis +/- reversed
« Reply #1 on: November 17, 2021, 07:43:21 PM »
Just reverse the motor from "motors" page. Sure must be many with that "problem" :) but the solution is super easy.
« Reply #2 on: November 17, 2021, 11:35:38 PM »
Thanks for the quck reply.
I did try that but no joy.
« Reply #3 on: November 18, 2021, 07:44:56 AM »
With what command you see it reversed? With keyboard, from g-code Z+/Z- or when you homing?
« Reply #4 on: November 18, 2021, 10:56:07 AM »
Thanks for the reply.
The problem was in the Config>Plug-Ins>UC-100 CNC Drive>Step/Dir Settings; the check box "neg" was set. Unchecking the box fixed problem.
