Hello Guest it is October 23, 2026, 08:30:32 PM
Author Topic: Mach Turn Problem I have.  (Read 22145 times)
« on: November 06, 2021, 09:08:34 PM »
Not very often I pull out my diy lathe. This problem often pops up and I have no idea what to do to fix it. I think it must be a homing problem? Or something else? Some advice please be great.
Pic one (not fail) is Mach Turn on my laptop inside my house. Same code. Looks fine, will probably work well. The other pic, has the tool trying to travel back behind the stock, way out the front of the chuck, back, then might, if I am lucky begin the cuts I have programmed into the code. But I dont have enough room for all this unnecessary movement. So this is the same piece of code just one loaded into different copies of Mach.
I have absolutely no idea why it does this?
Re: Mach Turn Problem I have.
« Reply #1 on: November 08, 2021, 11:08:45 AM »
Post the code please!
