Hello Guest it is November 13, 2026, 12:45:00 PM
Author Topic: The Bridgeport has Interlube  (Read 22579 times)
Offline Katoh
  •  287 287
« on: October 20, 2021, 08:42:00 AM »
Hi freinds, This is a build that I have been working on and off now for many years, but I have had a big push and shove to get it finished and running.
Its a series 2 J head Bridgeport, running AC 750W servos on all axis and one for a 4Th A axis, I am using the original 1.5hp motor VFD controlled but have put an encoder directly driven of spindle for feedback for, positioning and RPM. This will be controlled by Mach3 and uses the VitelSystems interface.
All the Mechanical aspects on this mill are complete just wiring to go which brings me to my issue.
The mill is equiped with an interlube automatic way's oiler, the only thing I have no specs on it nor wiring digrams ect.
I am hoping somebody knows something about these units that can direct me on the correct way to wire this to the system. it was disconnected when purchased I am not even certain what  voltage/amps it requires to operate.
Katoh
Katoh
