Hello Guest it is November 10, 2026, 01:57:28 AM
Author Topic: error G31 Probing Arrays  (Read 41408 times)
« on: October 18, 2021, 05:17:10 AM »
GOOD MORNING
I downloaded the G31 Probing Arrays macro from the MACH TOOL BOX section
I installed "M1299.m1s" then I launched "G31ExtPolArrayV2.01.txt" and it gives me an error
I corrected the first line M1289 with M1299
Gcode starts but when the "G1Z3110" line is reached the Z axis goes to the end of its stroke.
  (G31 External Polar Array V2.01)
   M1289
   M40
G90
  G0 Z # 110
  # 106 = [# 100 + # 102 * COS [# 103]]
  # 107 = [# 101 + # 102 * SIN [# 103]]
  G0 X # 106 Y # 107
  G1 Z # 123
  122 = Fix [# 122] <-------------- maybe it should be # 122 = Fix [# 122]
M98 P1 L # 122
G1Z3110 <-------- --------------------------------
M41
M30
o1 (sub1)
# 123 = [# 123 + # 121]
G1 Z # 123
  M98 P2 L # 108
  M99
o2 (sub)
  # 105 = [# 103 + # 104]
  # 106 = [# 100 + # 102 * COS [# 105]]
  # 107 = [# 101 + # 102 * SIN [# 105]]
  G90
  G0 X # 106 Y # 107
  G31 X # 100 Y # 101
  # 103 = # 105
  m99
given its usefulness it would be possible to correct it
I use version 3.043.062
I thank those who can help me
Re: error G31 Probing Arrays
« Reply #1 on: January 29, 2022, 06:42:23 AM »
Yes, well that line tells z to move up to 3110 mm!  So it's doing what the code tells it to. Looking a few lines above maybe the 3 should be # ?
« Reply #2 on: January 29, 2022, 05:41:27 PM »
YEP the 3 == #
« Reply #3 on: January 31, 2022, 11:56:38 AM »
thanks for the reply, the macro has improved
now it starts goes into position it goes down then it goes up again and it stops
I don't know maybe the problem is that I have a Chinese card?
« Reply #4 on: January 31, 2022, 12:17:26 PM »
Apart from correcting that error with the Z move, have you corrected the obvious 122 = fix[# 122] ?  Note the spurious space between # and 122.
And...
o0001 (G31 Interior Polar Array V1.01)
   M1299
   M40
  G90
  #106 = [#100 + #102 * COS[#103]]
  #107 = [#101 + #102 * SIN[#103]]
  g0 Z#110
  g0 X#100 Y#101
  G1 Z#111
  G31 X #106 Y #107
  G4 P1
  G0 X#100 Y#101
M98 P1 L#122
G1 Z [#111+121] <<121 should be #121?
M41
M30
o0001 (SUB1)
  M98 P2 L#108
  G0 Z#110
  m99
o0002 (SUB2)
  #105=[#103+#104]
  #106 = [#100 + #102 * COS[#105]]
 #107 = [#101 + #102 * SIN[#105]]
 G90
 G31 X #106 Y #107
 G4 P1
 G0 X#100 Y#101
 #103 = #105
 m99
There could be other simple errors too given that these only needed a quick look to see.
« Reply #5 on: February 01, 2022, 02:01:52 AM »
JohnHaine thanks for the help, I did as recommended but still have the same problem
« Reply #6 on: February 01, 2022, 03:51:18 AM »
I notice that the macro you posted first starts:
   M1289
   M40
However the macro it calls first, M1289, is not correct, it should be M1299!  This has been pointed out elsewhere on the forum.
Was the code you downloaded like this?  It's very careless.
« Reply #7 on: February 01, 2022, 04:20:50 AM »
I have renamed the macro M1299, the probing starts from the center goes to the beginning of the probing the Z goes down then goes up and stops everything and tells me the machining is finished. programming I do not understand but I assume that there is some problem in writing the macro
Offline TPS
  •  2,627 2,627
« Reply #8 on: February 01, 2022, 11:12:47 AM »
this code has to in M1299.M1s in your macro folder:
Code: [Select]
' G31 Polar Array Calibration Macro V1.00
Xpos= getdro(0)
Ypos= getdro(1)
Pspeed= Question (" Probe Feed Rate")
Rleg= Question ("Input Max Leg Length")
Linc= Question ("Input leg Separation Angle")
SafZ= Question ("Input SafeZ Height")
Phgt= Question ("Input Safe Probe Height")
Spnt= Question ("Input start point in DEG, zero is x axis 3oclock")
Tdeg= Question ("Input Total Arc Width of Array in DEGs")
Nrep= (Tdeg / Linc)
Setvar (100 , Xpos)
Setvar (101 , Ypos)
Setvar (102 , Rleg)
Setvar (104 , Linc)
Setvar (108 , Nrep)
Setvar (109 , Pspeed)
Setvar (110 , SafZ)
Setvar (111 , Phgt)
Setvar (103 , Spnt)
Code " F#109"
End
and this is the GCode you have to run (it will call M1299)
Code: [Select]
   M1299
   M40
  G90
  g0 Z#110
  g0 X#100 Y#101
  G1 Z#111
  G31 X #106 Y #107
  G4 P1
  G0 X#100 Y#101
M98 P1 L#122
G1 Z [#111+121]
M41
M30
o0001 (SUB1)
  M98 P2 L#108
  G0 Z#110
  m99
o0002 (SUB2)
  #105=[#103+#104]
 G90
 G31 X #106 Y #107
 G4 P1
 G0 X#100 Y#101
 #103 = #105
 m99
bbut i have no ideas what it will/should do.
« Reply #9 on: February 02, 2022, 01:07:21 AM »
Good morning
perhaps I have not explained myself well, in summary
I renamed M1289.txt in M1299.m1s and installed in MACH3 \ MACROS \ MACH3MILL, the problem is this:
I launch the program
he asks me for the various parameters
asks me where to save the tripletfile
starts the machine positions itself for the descent
goes down
goes back
at this point it tells me the finished work.
