Hello Guest it is November 13, 2026, 09:37:02 AM
Author Topic: Mach3 THC301d pin numbers  (Read 21788 times)
« on: October 14, 2021, 05:43:59 PM »
I running Mach3 with a Texas Microcircuit THC301d with a parallel cable to com port 2. Everything was working fine till my break out broad for the servos went dead. Got a new break out broad installed and got it up and running but my THC doesn't work. I think I changed a few pin numbers. I should have recorded everything. Does any one have an installation manual or the the pin numbers for the inputs and outputs used by the THC301d.
Inputs port 2
E-Stop
THC on
THC up
THC down
Outputs port 2
I do not know what's needed for outputs.
