Hello Guest it is October 25, 2026, 02:15:53 AM
Author Topic: Empty \Macros folder in newly created profile  (Read 9835 times)
Offline Azalin
  •  191 191
« on: October 14, 2021, 02:28:05 PM »
I created a new profile and noticed the machine doesn't respond to M6 command because the Macros folder was empty. So my question is if I copy and paste the macro files from the original Mach4Mill\Macros folder into my newly created profiles Macros folder, will them work?
Offline Bill_O
  •  615 615
Re: Empty \Macros folder in newly created profile
« Reply #1 on: October 15, 2021, 08:07:23 AM »
If the one you want to use worked then yes just copy it.
Offline Azalin
  •  191 191
« Reply #2 on: October 15, 2021, 08:08:54 AM »
Thanks Bill.
Offline Azalin
  •  191 191
« Reply #3 on: October 15, 2021, 08:52:21 AM »
I just need manual tool change so I'll take the M6 for sure but 162 and 163 seems like they are for dual spindle machines. My machine is just a 3 axis milling machine. Do I still need these?
M162   RIGHT SPINDLE WINDING CHANGE HIGH SPEED
M163   RIGHT SPINDLE FORWARD & UPPER COOLANT ON
Offline Bill_O
  •  615 615
« Reply #4 on: October 15, 2021, 08:54:59 AM »
You should only need the ones you will use.
Having said that the extras will not hurt if you never call it.
Offline Azalin
  •  191 191
« Reply #5 on: October 15, 2021, 01:23:07 PM »
I don't know why but it just doesn't work. Is there anything to be done other than copying the files?
Offline Azalin
  •  191 191
« Reply #6 on: October 15, 2021, 01:55:52 PM »
I found the solution here https://www.machsupport.com/forum/index.php?topic=30236.10 and it is very odd. If you disable LUA plugin then Mach4 doesn't include or read macro files at startup. Enabling it solved the problem.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #7 on: October 17, 2021, 02:47:41 PM »
You should only copy the .MCS files to the directory then mach4 will then recompile them.
DazTheGas
